Windows 7 nero could not perform start-dis-at-once
lucky2000
sinds een paar dagen krijg ik bij alle nero uitvoeringen(2017 of 2019) could not perform start-dis-at-once hoe komt dat nu??? ligt dat aan de disks??
Skippy
Kun je iets vinden in het log bestand ?
Dit kunt u hier vinden C:\Gebruikers\Uw gebruikersnaam\AppData\Roaming\Uw Nero versie\Nero Burning ROM
lucky2000
90A0-81C7-797W-KTMU-6PAM-42T9-****-****
907C-81CC-XM9M-W80H-E6M7-85EM-****-****
X026-204C-XZXW-7ZW1-1ZCZ-HZT5-****-****
X027-2070-TKPM-PZ31-M03E-KW26-****-****
X028-0083-29A5-AX8W-230U-91AM-****-****
Windows 7 6.1
AMD64
Wow64Process
Nero Version: 20.0.2.5
Internal Version: 20,0,2,5
Recorder : <hp BD B DH8B2SHB> FW version: SHDP - HA 1 TA 0 - 20.0.2.5
Device bus : <> HA 1
Host system bus : <S-ATA>
Drive buffer : 8192kB
Bus Type : via Inquiry data
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD/DVD-ROM : <hp BD B DH8B2SHB > FW version: SHDP - HA 1 TA 0 - 20.0.2.5
=== Scsi-Device-Map ===
: SAMSUNG MZ7PC128HAFU-000CXM0 iaStorA Port 0 ID 0 DMA: Off
: Hitachi HDS721010DLE630 MS2O iaStorA Port 0 ID 0 DMA: Off
: hp BD B DH8B2SHB SHDP iaStorA Port 0 ID 0 DMA: Off
=== CDRom-Device-Map ===
hp BD B DH8B2SHB F: CdRom0
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4095MB (4194303kB)
Free physical memory: 4095MB (4194303kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.3.2019
Burn DVD Image
16:38:55 #1 Text 0 File SCSIPTICommands.cpp, Line 617
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
16:38:56 #2 PHASE 214 File dlgbrnst.cpp, Line 2108
Generation of disc structures started
16:38:56 #3 IMAGEGEN -10 File ImageGen.cpp, Line 400
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 8547547136
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <E:\mijn documenten\Image.nrg>
16:38:56 #4 PHASE 215 File dlgbrnst.cpp, Line 2108
Generation of disc structures completed
16:38:56 #5 Text 0 File Burncd.cpp, Line 4190
Turn on Disc-At-Once, using DVD media
16:38:56 #6 Text 0 File DlgWaitCD.cpp, Line 336
[F: BD B DH8B2SHB ] Last possible write address on media: 4173823
Last address to be written: 4173606
16:38:56 #7 Text 0 File DlgWaitCD.cpp, Line 348
[F: BD B DH8B2SHB ] Write in overburning mode: NO (enabled: CD)
16:38:56 #8 Text 0 File DlgWaitCD.cpp, Line 3152
Recorder: hp BD B DH8B2SHB, Media type: DVD+R DL
Disc Manufacturer ID: <MKM>, Media Type ID: <003>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
16:38:56 #9 Text 0 File DlgWaitCD.cpp, Line 538
[F: BD B DH8B2SHB ] >>> Protocol of DlgWaitCD activities: <<<
16:38:56 #10 Text 0 File ThreadedTransferInterface.cpp, Line 879
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 4173607 (4173607) = #4173607/927:28.7
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4173607 blocks [F: hp BD B DH8B2SHB]
16:38:56 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [F: hp BD B DH8B2SHB] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8547547136, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 4173607 | 0 | 0x00
4173607 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD+R DL
16:38:56 #12 Text 0 File SCSIPTICommands.cpp, Line 404
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
16:38:56 #13 Text 0 File Burncd.cpp, Line 5088
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
16:38:56 #14 PHASE 24 File dlgbrnst.cpp, Line 2108
Caching of files started
16:38:56 #15 Text 0 File Burncd.cpp, Line 5210
Cache writing successful.
16:38:56 #16 PHASE 25 File dlgbrnst.cpp, Line 2108
Caching of files completed
16:38:56 #17 PHASE 36 File dlgbrnst.cpp, Line 2108
Burn process started at 8x (11.080 KB/s)
16:38:56 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
16:38:56 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x09b47e00: Len x648
16:38:56 #20 Text 0 File DVDPlusDualLayer.cpp, Line 1945
GetDriveCaps: LAST LBA of layer 1 is 0
16:38:56 #21 Text 0 File DVDPlusDualLayer.cpp, Line 1464
SetDriveCaps: Set LAST LBA of layer 1 to 2086815
16:38:56 #22 Text 0 File DVDPlusDualLayer.cpp, Line 1945
GetDriveCaps: LAST LBA of layer 1 is 2086815
16:38:56 #23 Text 0 File DVDPlusDualLayer.cpp, Line 622
Disc finalized, LBA total Image size: 4173616 (8151MB), Last LBA L0: 2086815 (4075MB)
16:40:02 #24 SPTI -1511 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1511)
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x3E
Sense Qual: 0x02
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 3E 02
Buffer x09c27880: Len xc
0x00 0A 00 00 00 00 00 00 00 1F D7 A0
16:40:02 #25 Text 0 File DVDPlusDualLayer.cpp, Line 800
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
16:40:02 #26 Text 0 File DVDPlusDualLayer.cpp, Line 1464
SetDriveCaps: Set LAST LBA of layer 1 to 0
16:40:02 #27 CDR -1511 File ThreadedTransferInterface.cpp, Line 1921
Logical unit timeout
F: hp BD B DH8B2SHB
16:40:02 #28 TRANSFER -27 File ThreadedTransfer.cpp, Line 1235
Could not perform start of Disc-at-once
16:40:02 #29 Text 0 File DVDPlusDualLayer.cpp, Line 1464
16:40:02 #30 Text 0 File ThreadedTransfer.cpp, Line 275
Pipe memory size 83836800
16:40:02 #31 PHASE 38 File dlgbrnst.cpp, Line 2108
Burn process failed at 8x (11.080 KB/s)
16:40:02 #32 Text 0 File SCSIPTICommands.cpp, Line 454
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
16:40:02 #33 Text 0 File Cdrdrv.cpp, Line 12297
DriveLocker: UnLockVolume completed
16:40:02 #34 Text 0 File SCSIPTICommands.cpp, Line 617
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
====== *** Nero Burning ROM, History File *** ======
Windows 7 6.1
AMD64
Wow64Process
(Nero Express)
Recorder : <TSSTcorp CDDVDW SE-208DB> FW version: TS01 - HA 1 TA 2 - 20.0.2.5
Host system bus : <USB 2>
Drive buffer : 1024kB
TSSTcorp CDDVDW SE-208DB D: CdRom2
Linux File-CD Gadget R: CdRom1
AutoRun : 0
Excluded drive IDs:
BUFE : 0
Memory in use : 33 %
10.3.2019
Burn DVD Image
17:18:38 #1 Text 0 File SCSIPTICommands.cpp, Line 617
17:18:38 #2 PHASE 214 File dlgbrnst.cpp, Line 2108
17:18:39 #3 IMAGEGEN -10 File ImageGen.cpp, Line 400
DAOI:
TocType = 0x00
Finalized = 1
1: ISRC = ''
Blocksize = 2048
TrackConfig = 0x00
CUES:
17:18:39 #4 PHASE 215 File dlgbrnst.cpp, Line 2108
17:18:39 #5 Text 0 File Burncd.cpp, Line 4190
17:18:39 #6 SPTI -1066 File SCSIPassThrough.cpp, Line 225
CdRom2: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xFF 09 03 01 00 00 00 00 00 00 00 AA
Sense Code: 0x24
Sense Qual: 0x00
17:18:39 #7 Text 0 File Mmc.cpp, Line 22817
Clearing LTRW/Archival mode failed, verifcation failed
17:18:39 #8 Text 0 File DlgWaitCD.cpp, Line 336
[D: CDDVDW SE-208DB ] Last possible write address on media: 4173823
17:18:39 #9 Text 0 File DlgWaitCD.cpp, Line 348
[D: CDDVDW SE-208DB ] Write in overburning mode: NO (enabled: CD)
17:18:39 #10 Text 0 File DlgWaitCD.cpp, Line 3152
Recorder: TSSTcorp CDDVDW SE-208DB, Media type: DVD+R DL
17:18:39 #11 Text 0 File DlgWaitCD.cpp, Line 538
[D: CDDVDW SE-208DB ] >>> Protocol of DlgWaitCD activities: <<<
17:18:39 #12 SPTI -1066 File SCSIPassThrough.cpp, Line 225
Sense Code: 0x24
Sense Qual: 0x00
17:18:39 #13 Text 0 File Mmc.cpp, Line 22817
17:18:39 #14 Text 0 File ThreadedTransferInterface.cpp, Line 879
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4173607 blocks [D: TSSTcorp CDDVDW SE-208DB]
17:18:39 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [D: TSSTcorp CDDVDW SE-208DB] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
DAO layout:
MediaType: DVD+R DL
17:18:40 #16 Text 0 File SCSIPTICommands.cpp, Line 404
17:18:40 #17 Text 0 File Burncd.cpp, Line 5088
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
17:18:40 #18 PHASE 24 File dlgbrnst.cpp, Line 2108
17:18:40 #19 Text 0 File Burncd.cpp, Line 5210
17:18:40 #20 PHASE 25 File dlgbrnst.cpp, Line 2108
17:18:40 #21 PHASE 36 File dlgbrnst.cpp, Line 2108
Burn process started at 6x (8.310 KB/s)
17:18:40 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926
17:18:40 #23 Text 0 File DVDPlusDualLayer.cpp, Line 1945
17:18:40 #24 Text 0 File DVDPlusDualLayer.cpp, Line 1464
17:18:40 #25 Text 0 File DVDPlusDualLayer.cpp, Line 1945
17:18:40 #26 Text 0 File DVDPlusDualLayer.cpp, Line 622
17:21:40 #27 SPTI -600 File SCSIPassThrough.cpp, Line 225
CdRom2: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0cd317c0: Len xc
17:21:40 #28 Text 0 File DVDPlusDualLayer.cpp, Line 800
17:21:40 #29 Text 0 File DVDPlusDualLayer.cpp, Line 1464
17:21:40 #30 CDR -600 File ThreadedTransferInterface.cpp, Line 1921
Device not available
17:21:40 #31 TRANSFER -27 File ThreadedTransfer.cpp, Line 1235
17:21:40 #32 Text 0 File DVDPlusDualLayer.cpp, Line 1464
17:21:40 #33 Text 0 File ThreadedTransfer.cpp, Line 275
17:21:40 #34 PHASE 38 File dlgbrnst.cpp, Line 2108
Burn process failed at 6x (8.310 KB/s)
17:21:40 #35 Text 0 File SCSIPTICommands.cpp, Line 454
17:21:40 #36 Text 0 File Cdrdrv.cpp, Line 12297
17:21:40 #37 Text 0 File SCSIPTICommands.cpp, Line 617
Skippy
Dit stukje:
Dit kan duiden dat het station ( de brander dus ) defect is. Device not available
Misschien een vuile laser ?
Skippy
Probeer eens op een hele lage snelheid te branden. Misschien een geheugen probleempje met de PC waardoor de branders gezien worden als niet beschikbaar.
Het is toevallig natuurlijk maar misschien twee defecte branders.
Uit de log maak ik niet op dat het aan de schijfjes ligt. Maar misschien wordt zoiets niet weergegeven ??
